Holley Annihilator/mallory Unilite - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2004, 06:48 PM
400C53F100's Avatar
I have a Holley Annhilator CD unit and a Mallory Unilite Dist. also a Mallory Promaster coil. I have had this setup for a few years. It used to run great, but more recently I have had some trouble with it. After a new cylinder head change, I can't get it to run right. It misses and loads the plugs up. I disconnected the Holley unit and hooked the ignition up as a conventional igntion. I runs fine that way. After running with the CD unit disconnected, I reconnect it and the problem returns. I would like to use my CD unit. Should I bite the bullet and replace the Holley CD unit? What should I replace it with. I don't like the MSD 6AL, because of the rev limit plugs.
Old 05-06-2004, 11:54 AM
bullheimer's Avatar
NEVER use credit cards!
i know this might sound stupid. but since i dont know anything about that holley unit, this is all i got. everytime i see the word uni-lite and trouble running i have to tell people about how my unitlite with a std coil burned the conductor of my coil wire in half right in the middle of the wire so you couldnt see it. nothing on the outside or either end. had to pull it apart to see it. dont remember what made me do it but i had already replaced the module and it was still missing. soo, take an old peice of plug wire and stick it in there and see if anything changes.
Old 05-06-2004, 01:13 PM
Pony's Avatar
Have you called Holley tech line? The reason I asked is that I'm using a MSD6A and while working near the terminal block for the MSD hook up I shorted it out and killed the MSD unit. I called MSD tech, told them I screwed it up and asked how much to fix it. They fixed it for free and even paid return shipping. Bottom line, good companies are loyal to there customers and should make an effort to keep you as a customer.
Old 05-08-2004, 06:24 AM
400C53F100's Avatar
I think that I have found the problem. I have a 2 ft. length of coil wire between the Mallory Promaster coil and the Unilite Dist. It measures 19,000 ohms between the terminals. My plug wires were MSD, but that coil wire was some brand X resistor wire. The spark energy must have cooked the conductor over time.
I just got a new set of Taylor Universal Spiro-Pro wires. This set has a 36" length of Coil Wire. I just have to terminate it and install it. I'll get that done today and see if that fixes the problem.
Old 05-10-2004, 06:07 PM
400C53F100's Avatar
Replacing the coil wire did not fix the problem entirely, but I did find evidence of tracking inside the Mallory cap. I have a new cap and rotor ordered.
I would like to change to a MSD distributor with a 5" diameter cap, but the short term fix is to replace the cap and rotor.
Has anyone run a MSD dist with a 5' cap?
Old 05-10-2004, 09:31 PM
Pony's Avatar
Are you sure that the length of your coil wire isn't your root problem. Cd units fire the plugs 2 to 3 time each cycle below 3,000 rpms vs the stock set up firing only once. It seems like a long coil wire could come into play. Iv'e always been told to keep the coil wire a short as possible on high output coils although I can't find it in writing anywhere and don't know that for a fact myself. This board has a lot of sharp guys on it, you could always ask the board about how long is too long for a coil wire.
