holley avenger site glass leak on primary float bowl - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2012, 02:46 PM
glassratt's Avatar
Last journal entry: 1956 buick special
can this be fixed? have not taken bowl off yet ...searchin for fix first. instructions say site glass installed...press fit? leaks like a sprinkler with 7 psi fuel pressuer...any words of advice?want to fix iff possable,
Old 06-10-2012, 02:48 PM
glassratt's Avatar
instructions say factory installed site glass
Old 06-10-2012, 03:07 PM
cool rockin daddy's Avatar
Uhhhhhhh, what are you going to do? If it leaks, you have to replace the bowl its pressed into. If you can repair, you'll have to take the bowl off. Start hotrodding and fix it!
Old 06-10-2012, 03:40 PM
They do not last. Replace with brass.
I believe the instructions on my street avenger said they are temporary.
Old 06-10-2012, 03:42 PM
glassratt's Avatar
fix
well thanks lol, on your responce...it never hurts to ask questions before a tearin...Iam not shy on hot rod fixing if you see my project journals or rides.....just started geting back into carbs again....been doing elec /mechanical fuel injection.I have never heard of new carbs out of the box leakin in the site glass ? this is poor quality from holley.allstate carbs "ever heard of them",they seem to have good prices on holley replacment float bowls $ 22.95 primary with floats and gaskets...know of a better place to go or deal ?thanks for your time
Old 06-10-2012, 04:05 PM
jdhemin's Avatar
check in with summut racing( catolog or online) or jegs they both have a nice selection of holley parts
Old 06-10-2012, 06:40 PM
I figured you weren't a noob, that's why I figured to remind you that either way, you're gonna have to take it apart. No harm meant and I'm glad you didn't take offense.
Yeah, Jegs or Summit are the places I use. Wish there was a local speed shop around here but Ramchargers closed up about five years ago.
Weird leak from Holley Fuel bowl 98 SNAKE EATER Engine 4 08-01-2012 10:14 PM
Holley Primary Booster Leak jjgrizz73 Engine 6 01-29-2011 06:42 PM
Gasoline bubbling in float bowl? jlb5001 Engine 8 07-22-2008 10:16 AM
bowl inlet to inlet on a 770 street avenger? spinn Engine 1 01-23-2008 12:37 PM
Holley carb - Float bowl adjustment gilby246 Engine 8 01-16-2007 06:39 PM
