holley to barry grant switch questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2005, 07:42 PM
I have an 850 vac secondary holley on my ZZ502. I am going to switch to a Barry Grant 850 Speed Demon. What are the differences in the two carbs? Will I need to change anything (ie. fuel hookups, ect)? What are the main differences between the two carbs? Does the barry grant have a power valve? Any other info is appreciated
Old 10-02-2005, 08:28 PM
lluciano77's Avatar
Short changed on common sense
They should be a direct swap. You may need to change a vacuum line, but it is unlikely.
Barry Grant Carbs are almost exactly like Holleys. They have Holley powervalves. Most of their parts are Holley interchangeable.
I suggest if you run a BG or a Holley, you should learn as much as possible about their components and how to tune them. There are plenty of good books out there that will tell you everything.
A vacuum guage is also necessary. It is the most accurate way to tune the idle mixture. I don't leave home without one. Mine has a permanent place in my trunk.
Old 10-02-2005, 08:40 PM
what about fuel inlet thread size? are they the same? or will I have to get a new fuel feed line?
Old 10-02-2005, 08:43 PM
lluciano77's Avatar
If you have the 7/8" or whatever it is fuel line I think it will fit. The 3/8" fuel line won't if I am not mistaken. Either way the local parts house should have a fuel line that will work.
Old 10-18-2005, 08:49 AM
Technical Support Barry Grant
Swapping Holley to Demon
You will need to purchase a new dual feed line as our inlet fittings, and center to center distance are different than on a Holley. You will also need to either modify your exsisting air cleaner, or get one specifically designed to fit a Demon. The choke towers are larger on a Demon to increase the air flow, so the air cleaner has to clear the choke linkage. Other than those two things the rest of your items should interchange. If you have any questions, please contact our technical department at (706) 864-8544.
That lousy Holley carb cool rockin daddy Engine 30 02-29-2008 02:01 PM
Barry Grant 650 Speed Demon vacuum secondary discussion requested. commando57 Engine 3 09-15-2005 12:55 PM
Holley 650 D.P. questions? juveteach Engine 13 07-31-2003 03:40 PM
Holley tuning questions. F-1Rodder Engine 16 06-14-2003 01:20 PM
HOLLEY 600 4160 CARB QUESTIONS? mr_chickenhead Engine 3 05-22-2003 02:57 PM
