Holley Baseplate Screws - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2006, 09:04 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Im thinking about swapping out the main body on my 750DP this weekend with a Proform piece I picked up from a friend. I've been told I should use an ever so small amount of loctite on the threads of the baseplate screws. Which loctite should I use? I know theres super strong stuff and not so strong stuff but I cant remember which is which.
Old 03-10-2006, 10:16 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Blue (loctite 242) is medium strength, red(loctite 262) is high strength. I'd use the blue, as you may need to take it apart again, and aluminium is not compatible with the 400*+ to get the red stuff to let go.
Old 03-10-2006, 10:39 PM
97Z28's Avatar
NTI Grad.
agreed. the blue loctite will let loose with a screwdriver... but it'll be rough, wont shake lose on ya thats for sure. you put the red on it and you might as well throw the carb away if you ever have to rebuild it cuz the screws wont come out.
Modifying Holley baseplate so power valve references manifold on s/c motor blownS10blazer Engine 3 09-05-2008 10:21 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Holley baseplate bushing kit 83Silverado Hotrodding Basics 2 05-15-2004 12:28 AM
Idle Screws Do Nothing?? (holley) STBR Engine 11 10-11-2003 09:49 AM
750 Holley Dbl Pump Baseplate NAIRB Engine 1 01-14-2003 06:51 PM
