Holley "Blue" rebuilt as a "Red" pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2005, 11:54 PM
lluciano77's Avatar
Short changed on common sense
I have a Holley Blue pump that works fine. The regulator that came with it doesn't work.
Is it possible to rebuild a Blue pump using a Red pump kit? It would be easier for me to have the pump itself regulate the fuel pressure.
Old 05-17-2005, 09:48 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Never fooled w/ Holley pumps but if I did, I would call or FAX the Holley tech dept. with a question like that one.
Old 05-17-2005, 12:01 PM
347mustang's Avatar
the only dofference bteween the holley blue and red and maybe the black,but the blue and red for sure is the relieve spring...the spring is like 5.00..there is a screw on the side..undo it ..be care it may fly out and dont loose the check ball...instll the new spring..and bam..a 7 psi pump to a 14..or a 14 to a 7
Old 05-17-2005, 08:41 PM
lluciano77's Avatar
I used to have a red pump. I hope I didn't throw it out. The motor was burnt up in it, but I'm sure the spring is still good.
Mechanical or Electrical Fuel Pump lakecityg Engine 5 06-21-2003 09:27 AM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
Holley blue fuel pump install edubois Engine 7 02-23-2003 06:58 AM
750 Holley Dbl Pump Baseplate NAIRB Engine 1 01-14-2003 06:51 PM
