Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley carb
Thread: Holley carb
Old 05-15-2002, 05:29 PM
Dustin Dustin is offline
[quote]Originally posted by johnnymopar:
<strong>i'm not sure about the power valve's function, but i think you're going to have to take your carb apart. If it is draining dry then the first thing i would check is your main inlet valve. Check your floats and make sure that the valve is shutting properly. Also check out your accelerator pump and make sure that the rubber washer is in good condition and sealing inside its well. These are two main things that could be causing you problems. If your carb is generally in poor condition then i would suggest that you rebuild it.
Good Luck
I had the same prob with mine. I found out that the float bowls are draining due to not sealing. My accelurator pump was bad. The gasket was bad.
