holley carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2009, 07:35 PM
pena0724's Avatar
holley carb
I have a 350 Chevy I just rebuilt it runs great but when i punch it it is a little bloggy until i let off the gas and back on it. I have a Holley carb 650 cfm double pumper no vacuum advance. I was told i probably need larger jets is this true? what may my issue be.I have also victor jr intake
Old 05-20-2009, 04:00 AM
Last journal entry: 50 Ply wagon
Did you adjust the accelerator pump lever? It should be adjusted to between .015-.020. Is fuel bowl level correct? Check your plugs to see how rich or lean the motor is running. But those adjustments if not right, will be part of your problem.
Old 05-20-2009, 04:23 AM
Bog
If it goes when you let off it might be to lean.When you open the throttle that means more air is coming in.Either accel pump promblem or just to lean.Is there black smoke when you get on it.Could be choke pull off promblem and to much fuel.Look for black smoke.No smoke start looking for lean condition.
Old 05-20-2009, 09:15 AM
dawg's Avatar
NAVY VETERAN
here is how I fixed mine
I took off the accel pump arms and straightend the bend a bit
(holley has had an issue with weak accel pump arm springs)
I then turned the spring adjustment all the way down to just before spring bind.
re installed arms and adjusted for .015 between the pump arm and diaphram arm at wide open throttle.
adjusted so that the slightest movement causes squirters to squirt or dribble fuel
then road test
mine was fixed
now when I punch the throttle rear tires spin like no tomarrow at a standstill.
also you might try various cams and shooters is it gets better but doesnt solve the problem entirely.
« cooling | dyno sim »
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 02:28 PM
Edelbrock or Holley Carb. for my street/strip Truck anthony4401970 Engine 9 02-26-2008 12:03 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
Holley Carb Tuning Coleman396 Engine 4 07-19-2003 10:03 AM
