Holley Carb Backfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 08:13 PM
DeathRattle's Avatar
Some Punk Kid
Engine is SBC with a holley 670 street avenger sitting on top. Finally got the starter working well so I tried to start it. I only get pops and plumes of smoke out of carb. Should i be only looking at timing or anything else. Maybe something stupid like not enough plug gap? I thought I set it up well but I could be off a tooth.
Crank motor to 10* piston 1 @ TDC.
Aligned oil pump drive with intake pushrod of #5
Mark distrib. body with number one point.
Pointed rotor at with oil pump drive and dropped it in.
It aligned with number one mark and vacuum can was angled 45* across motor.
Tell me if and where i went wrong
Thanks for any replies.
Old 12-26-2006, 08:27 PM
71C10's Avatar
U.S. Army Retired
Make sure you are the compression stroke... the rotor has to be pointed a little counter clockwise of (#1) on the cap when you drop the dist in, (before it meshes with the cam gear) because it rotates clockwise when it meshes with the cam gear.
Old 12-26-2006, 09:01 PM
Yes, you are not timed correctly.
Old 12-26-2006, 09:31 PM
Some Punk Kid
Im sure their are different techniques than the one I used so I am open to suggestions for setting initial distributor timing. I followed the on in the book which was oil drive shaft aimed at intake pushrod for number five cylinder when piston one was at top dead.
EDIT: When it backfires through carb is it more realistic that its off a tooth? or do I just to turn the distributor? I would think if its doing that its way off more than turning can fix.
Old 12-26-2006, 10:31 PM
71C10's Avatar
U.S. Army Retired
The cam turns one revolution for every two crankshaft revolutions... are you sure that you were on the COMPRESSION stroke of #1 when you dropped the distributor??? If you are doing this by yourself, pull the drivers side valve cover and crank the engine until the INTAKE valve of #1 opens and begins to close, then crank the engine by hand until you get to the approx initial timing you want and drop the distributor in place. Turn the oil pump shaft if you must... and make sure the rotor is pointed at #1 on the cap once the dist is down flush against the manifold.
Good luck and hang in there!
Old 12-26-2006, 10:46 PM
larryblack's Avatar
Certified Lead Foot
Originally Posted by 71C10
The cam turns one revolution for every two crankshaft revolutions... are you sure that you were on the COMPRESSION stroke of #1 when you dropped the distributor??? If you are doing this by yourself, pull the drivers side valve cover and crank the engine until the INTAKE valve of #1 opens and begins to close, then crank the engine by hand until you get to the approx initial timing you want and drop the distributor in place. Turn the oil pump shaft if you must... make sure there rotor is pointed at #1 on the cap... once the dist is down flush against the manifold.
After you do the previous excellent instructions, connect your timing light to number 1 plug wire. Turn the key on, and adjust the dizzy CCW until the light flashes. You now have the initial timing set. I like to alaign the balancer marker with the 10 on the tab. It is a good starting point. Tighten the dizzy down and fire the engine.
You will still get some poping thru the carb if this is a new cam/engine set up. after a couple of minutes things will settle down and you can watch for leaks and beak in the cam if need be.
Old 12-27-2006, 10:55 AM
Some Punk Kid
Thanks for he advice I am about to go out and do all of this again and see how she goes.
Old 12-27-2006, 02:04 PM
Some Punk Kid
It was 180 out. Break in went smooth. Max temp at 2000-2500RPM was 200 I will change oil and fire it back up and hopefully cam has all its lobes. With rotella and EOS it better. I hope
Old 12-27-2006, 04:11 PM
71C10's Avatar
U.S. Army Retired
Good deal, enjoy
Old 12-27-2006, 05:44 PM
Some Punk Kid
Now I have to just get it to idle. If i let off the pedal it stalls. I guess ill just have to fiddle with the idle speed screw and see is i can get it to idle
Holley (ProForm) Carb Problem leejoy Engine 29 04-01-2011 11:36 AM
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 02:28 PM
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
