Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holley carb backfires threw carb
Old 01-25-2008, 10:09 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
You can run a compression check too.If you have 0 on one of the cylinders then you can back of on the rocker a little to see if your compression comes up on that cylinder.And if it does come up,then you will need to reset all of your rocker's.Check all that everyone is telling you first.
