Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holley carb backfires threw carb
Old 01-26-2008, 11:45 AM
454C10 454C10 is offline
back firing out the carb is a sign of retarded ignition timing and/or a lean mixture.
with only around 13 inhg of vacuum, i would say you need about 20 degrees of initial timing.
you might also need a bigger accel squirter. pull the one off your holley and read the number off it, then go up 3 or 4 steps.
