Well to start off torque them down about 5 to 6 ftlbs and no more. Make sure you snug the bolts in a criss cross pattern first then torque them down. I do mine about that much and it works out fine. If you use just regular bolts on your carburetor and using lock washer put a regular washer down first then the lock washer then the bolt. I use carburetor studs instead of bolts but either way works.
Eric |
Thanks. |
The bowl gaskets will almost always tear if the carb has been in service long. If they do, you'll want to replace them. Even the "non-stick" gaskets WILL stick, so be prepared. Tighten the bowls in a couple stages, in a criss cross. The exact in/lb of torque of the various fasteners I have never known, I tighten them all "snug", then recheck after the engine has run a few times. What you want to avoid, is to overtighten the fasteners, yet be tight enough to not leak. |
Sorry about what I stated. I thought you meant the carb to intake. Just like cobalt said tight enough but not too tight. I usually just tighten up each screw in a criss cross pattern till they are snug then wrist tighten them and thats it. After a few heat cycles I check them and make sure they are still tight. Don't crank it hard but just enough to make it snug by turning your wrist with a nut driver.
Eric |
| Holley Carb Gas Leak | 64Joker | Engine | 21 | 07-18-2010 02:28 PM |
| Rant about aftermarket sheetmetal | cyclopsblown34 | Body - Exterior | 27 | 01-28-2010 10:14 AM |
| Carb selection help | SLR_65 | Engine | 2 | 09-03-2007 05:44 PM |
| edelbrock vs. holley carb | Super Chevy | Engine | 43 | 01-21-2006 09:55 PM |
| Removing fenders? | Jag Daddy | Body - Exterior | 3 | 11-26-2003 04:42 AM |
