Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley carb - Float bowl adjustment
Old 01-16-2007, 09:11 AM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
Try swapping the N&S from the front bowl that you know works properly to the rear bowl. This will let you know if the problem is in the N&S assembly or possibly the bowl itself. Also, make sure to put some lubricant on the o-ring so that it doesn't get cut when you install the N&S into the bowl.
