Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley carb - Float bowl adjustment
Old 01-16-2007, 06:39 PM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
If the same bowl is having a problem setting the float level with different floats, and N&S assemblies the hole through the bowl may be a touch over sized causing fuel to leak around the outside of the o-ring on the N&S assembly. If you have some extra o-rings you might have one that is a touch bigger and it would help otherwise you'll want to check with Holley.
