holley carb flooding - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2009, 04:53 PM
wildthing's Avatar
Last journal entry: 95 % done
ok well i had a friend give me a used carb its a 4160 holley. we rebuilt it over the winter following the instructions " very limited " with the rebuild kit.
today i tryed to fire the car up for the first time , as iam pulling the #1 plug to set top center , about the third time i check it the clylinder was full of fuel it splashed out when we bumped the engine over.
looking at my trouble chart it says floats or needle valve. i pulled out the float check screws they levels are ok. so " how do i fix it "
Old 04-12-2009, 05:16 PM
DoubleVision's Avatar
If your sure the float levels are okay next up is to check the fuel pressure. If the engine will idle or even if the fuel pressure is excessive, it will pour fuel out of the boosters so you`ll have to shine a light in the carbs throat to see while it`s idling or even turning over in a attempt to start. If you don`t have a fuel pressure gauge get one, Holley`s don`t like fuel pressure over 6 psi. Sometimes they will also flood out of the idle circuits, years ago when I was battling a fuel pressure issue, it would flood from the idle circuits or pour out of the boosters.
Old 04-12-2009, 05:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Did you put a power valve back in it? With the correct gasket? Windowed PV gets the plain round gasket, the multiple round holed one uses the gasket with the "bumps" on the ID- IIRC.
Old 04-12-2009, 08:00 PM
wildthing's Avatar
engine isn't running , it was just put back together. it has the stock ford mechical fuel pump.
yes it got a new power valve , i think correct gasket. it all came in the rebuild kit.
Old 04-12-2009, 11:44 PM
kleen56's Avatar
You should be fine with the stock Ford pump because they pump around 5 lbs. Are you adjusting the floats correctly? There is a screw on the side of the fuel bowl. When you remove that screw, you should have a very slight trickle of gas coming out. If it's pouring out of the hole, the float needle is adjusted too high and needs to be lowered until the fuel barely comes out of the hole. You may have a piece of gasket or dirt stuck in the float needle preventing it from shutting off the fuel supply, if adjustment isn't working. To adjust the float, use a 5/8 wrench to break the nut and float needle which is on top of the fuel bowl, while holding the float screw in place. Then turn the screw clockwise to lower and counterclockwise to raise the needle until the proper float level is achieved. Then tighten the nut and you should fine. The engine is probably not running due to all the fuel dumping into the engine. You may need to change the plugs or dry them off if they are gas fouled as well.
Old 04-13-2009, 06:36 AM
wildthing's Avatar
the bowls are not over full , i opened the check screws and the levels are just a bit below the opening.
holley carb backfires threw carb talleyho Engine 63 01-04-2016 11:43 AM
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 03:28 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 07:04 PM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 10:55 PM
Holley help needed. MAJOR FLOODING!! dirtydave Engine 11 08-16-2004 12:21 AM
