Holley Carb Gas Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2006, 04:33 PM
64Joker's Avatar
64Joker
Make: Chevrolet
Year: 1964
Model: Impala SS
Engine: 327
Tran: 350 Auto
Background: The car has been sitting for about 1 years without starting
the engine.
Problem: After replacing all the wiring harnesses, and other non-engine
tasks, the engine started with no problem, except a minor gas
leak on the Holley Carburetor.
Questions: Can anyone help identify the Holley carb (see attahced pic)?
Can I locate a model number somewhere on the carb?
Attached pic dsc03108 points a red arrow to where the leak is
located, the leak is actually on the bottom side of the arrow.
There is what appears to be a "brass" bold leading into the
leak area, can this bolt be tightened? I'm not sure how many
miles the carb has on it, but I have the car about 5 years.
If I need to replace the carb, what is recommended, assuming I stay
with Holley, budget is covservative.
Thanks in advance.....
Old 11-13-2006, 05:34 PM
Originally Posted by 64Joker
Make: Chevrolet
Year: 1964
Model: Impala SS
Engine: 327
Tran: 350 Auto
the engine.
That is called a banjo fitting, there are two flat gaskets on it, one on each side, it might be possible to tighen it slightly, just don't over do it.
It appears you have a 600 holley, the list number should be on the front of the choke tower.(1850-2) is a possibility.
Of course I could be wrong, I was once many years ago,LOL.
Old 11-13-2006, 06:06 PM
64Joker's Avatar
64Joker
Follow-up to dgcantrellsr
dgcantrellsr, It appears the carb is a List 1850-3, I took another pic (see attached). Does this still make it a 600 Holley? Thanks....
Name:	list 1850-3.JPG
Old 11-13-2006, 06:19 PM
nitro_baller4692's Avatar
floppers forever
yes it's a 600 cfm carb.
http://www.mortec.com/carbs.htm
Old 11-13-2006, 08:12 PM
64Joker's Avatar
64Joker
Flat Gaskets
Can I order the replacement flat gaskets for the Banjo fittings individually, or do I need to purchase a kit? Where can I locate the parts? Thanks again!
Old 11-13-2006, 08:22 PM
Bumpstick's Avatar
Hammer and a torch
Most auto parts stores should have this...
Old 11-14-2006, 08:51 AM
MI2600's Avatar
Member# 3287
I would try local speed shops.
My experience has been that if you run a Holley you better get used to black stains on your intake.
Old 11-15-2006, 03:31 PM
Yes its a 600, they make a -3 and a-4
Old 11-15-2006, 05:05 PM
floppers forever
yes here is a list of part #'s.
Old 11-15-2006, 05:26 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Best thing to do is get the complete kit....that carb has been siting around and every gasket, o -ring and seal in it is dried out. You fix one leak today you could have two more tommorrow. If you do not know how to put a kit in it then have a pro re-build it for you that would be the best anyway because it is going to need a good cleaning and with the price of carb cleaner like it is today you could probably pay to get it re-built cheaper than you could get a 4 gallon pail of carb cleaner.
Old 11-22-2006, 09:36 AM
64Joker's Avatar
64Joker
Task Complete
I successfully replaced the flat gaskets for the Banjo fittings, and there are no more gas leaks! Thanks to all........
Old 11-22-2006, 10:28 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
Even after getting mine rebuilt it leaked. I would fix one leak and in a few days it would leak at another spot. I gave up and purchased an edelbrock, they dont have any gaskets below the fuel level.
Good luck I hope it works out for you.
Old 07-17-2010, 12:17 PM
I have a leak in the same area, but not on the brass elbow. In the first pic just below the elbow you can see a screw on the undersie of the carb,,,I bealieve there is actually 4 screws holding some kind of plate up. Its impossible to get a screwdriver to it. ANyone know what this is?
Old 07-17-2010, 12:28 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Accelerator pump, You will need to remove the carb turn it upside down and drain the gas and probably re-place the pump, You can try to snug the screws up but probably won't fix the problem. You really more then likely will have to do a re-build on the carb once the pump starts leaking JMO, probably time to re-build. But get another pump and try to re-place it first if you want might just fix it. JMO And welcome to the site This thread is like 4 yrs old.
Cole
Old 07-17-2010, 12:42 PM
Thanks eloc,
Ill give it a shot. I knew this was 4 years old but had the picture i needed to explin my issue,,I appreciate it.
Holley Carb Leak GCD1962 Engine 3 03-18-2006 07:24 PM
Holley 750 Carb Leak tweeter400 Engine 25 02-17-2006 08:42 AM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Any Holley carb gurus out there? 65Cyclone Engine 14 10-26-2004 05:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
