Holley carb gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2006, 03:54 PM
Holley carb gasket
I have a older 4150 Holley mounted on a square bore intake. Carb had a square gasket with a thin 4 hole spacer,with another square gasket. Car ran good. I replaced carb gaskets with this time just a square gasket. Now, why the 4 hole spacer? Too thin to be an insulator. It's the same size as the gaskets. Could it be to help atomize the fuel? I think the engine ran the same,if any difference, not much, with or without the thin spacer. Now, if I put that thin spacer back on, should I now use four hole gaskets instead of the square hole gaskets with my square bore intake? I was concerned about a transfer slot on the bottom of carb that runs between main and secondary venturis. A four hole gasket would cover up that slot, although the thin spacer was anyway. Any thoughts on this?
Old 10-28-2006, 04:40 PM
Holley Carb
Vetteman, How thin is thin? I have a Corvette/Camaro LT-1 intake on my Chevelle's small block and I have a Moroso 4 hole phenolic spacer there for heat insulation and it is an inch thick. That helps add plenum volume. The 4 holes help with velocity. A more open one helps better with mid to upper rpms. If the car isn't run hard then a 1/4" thick "spacer" isn't gonna help much. It is most likely there for heat reasons. GM also made a heat plate for the Z-28 in the late 60s. Just get that and it'll keep the fuel bowls cooler.
« 305HO Cam | Exhaust »
Holley (ProForm) Carb Problem leejoy Engine 29 04-01-2011 11:36 AM
Trimming Carb Base Gasket maverick19642001 Engine 4 09-03-2006 10:47 PM
What holley 750cfm carb to go with ??? FiefSS Hotrodding Basics 17 09-29-2003 03:58 PM
Holley Carb Tuning Coleman396 Engine 4 07-19-2003 10:03 AM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
