-   -   holley carb help (http://www.hotrodders.com/forum/holley-carb-help-145340.html)
18camaro 09-19-2008 02:48 PM
holley carb help
what kind of carb do i have. the list number is 6210 30456. some other numbers are gr4237b, 8522, and 12r93598. im gonna buy a rebuild kit and need to know. thanks
squeeezer 09-19-2008 05:37 PM
renew kit=37-605
or
trick kit37-918
you have a holley 4165 carb
this carb was a double pumper for spread bore manifolds or replacing the quadra jet
they have these things in common with the 4150 double pumper
1power valves
2jets
3fuel bowls and accesories
4needle n seats/floats
5maybe even accelerator pumps too
squeeezer 09-19-2008 05:39 PM
ohhhhh and its a 650cfm carb
use part#r6210
18camaro 09-19-2008 10:32 PM
http://www.teufert.net/carbs/holley-cfm.htm thanks for the info with what you gave me i could check and it says its a 850. which is what the guy i bought it from said i just wasnt sure that he was sure but tht website says it is a 850 cfm
Stroke 09-20-2008 08:57 AM
All 6210 Holleys list out as 650's. This includes the 6210-1, 6210-2, and 6210-3 as per the two Holley books I have anyway. The 6211 and 6211-1 list out as 800CFM.
