Holley Carb ID. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2006, 10:11 PM
Holley Carb ID.
I have an old Holley Carb that was given to me. I want to rebuild it. None of the numbers that I can find match any resouces I have. Here are the numbers;
On Choke Horn:
D5TE-9510-CB
LIST 6945
2497
On a Metal Tag Attached:
D4TE CB 7J6
It is a Motorcraft model. (I think I can grind that off)
Old 02-03-2006, 12:21 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
It's odd that the metal tag and the stamped # don't match.
"Prefix": D4TE = 1974 ford truck, D5TE = 1975 ford truck
"Basic": 9510 is the ford "basic" number for a carburetor.
This basic number applies to any model of car or truck.
Because it is common to all carbs, it was usually omitted on those very small tags.
"Suffix": CB was used to identify variations. (Engine size, Auto Trans, Electric Choke, etc.)
My guess is that this is likely about a 600/650 CFM square-bore vaccuum-secondary Holley carb off of a 74/75 F100-350 pickup with a 390 4V engine.
Old 02-03-2006, 10:54 AM
just buy a 600 cfm vac quickkit;everything will work!!!
Old 02-03-2006, 07:00 PM
Thanks for the help!!! I'll let you know how it turns out!!
Old 02-05-2006, 09:09 AM
Holley carb
Hope you didn't buy that Holley "quickie Kit" yet. Holley
produced carbs for Ford but not everything is the same.
Some Ford Holleys have different metering bodies that only use Motorcraft jets. You won't find idle mixture screws on the metering block, they are located in the base plate. A lot of those floating around were made when everybody was nervous & jerky about emissions and fuel shortage so they are all jetted lean for a stock motor. If you need to jet them, you will have to go to a dealer, (hopefully you'll get someone older than the carb) and see if jets are still available. I had to buy a pack of 5 or 6 of the same number. Be sure to match holes in your gaskets with the old ones.
I've all but given up on old carbs because the metering orifices and venturies deteriorate from water, bad gas, dirt Etc. I might buy fuel bowls at flea markets to save some bucks and hang them on a Pro Form body.
Old 02-05-2006, 09:39 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
66gmc is right. it is a 600 cfm. the tag # is the only # that is usable. you will most likely need to go to ford for a kit. BUT you can buy a new 1850 for about the same cost. chunk the old one. it's 30 years old and probably trashed from electrolysis.
Holley Carb mr.Pinto Engine 5 07-27-2004 05:46 AM
What holley 750cfm carb to go with ??? FiefSS Hotrodding Basics 17 09-29-2003 04:58 PM
Holley Carb Tuning Coleman396 Engine 4 07-19-2003 11:03 AM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 01:36 AM
Proform replacement for Holley carb body, worth it? Pinardi Engine 2 01-07-2003 06:51 PM
