Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley carb interchangeability questions
Old 02-16-2005, 03:22 PM
commando57 commando57 is offline
Can a carb with a metering plate secondary (a 750), be changed to a carb with a metering block by swapping in the metering block from a 600. Both square bore, both vacuum secondary's, both center float pivot. Thanks for reading this.
