holley carb issues
Hi,
I have posted here before but its been a while. Bought a 1969 Chevy C10 a while back and I have been tinkering with it here and there. I have a holley 4 barrell (I am unsure of the specific model) with an edlbrock intake. The engine is a 350 MD out of a 73 gmc. I'm sure someone is going to read this and say to themselves: "What a friggin idiot." But hey, the only dumb question is the one not asked. Right? So anyways the truck runs like a dream up until i hit about 65-70 MPH. Then it starts acting like it is running out of gas. When I let off the gas a little it stops, but if I get back on it it does it again. Does the carb need any adjustment, or just a good cleaning? I will be driving the truck from Alabama up to NC soon. Most of the trip will be on I-85 and I would hate to have to drive it all the way up to NC like it is. If anyone has any suggestions I would appreciate it. |
You might try and raise the float a bit.
Go up on the jet size by 2 numbers change the power valve to a 6.5. Try the easiest first!! Only make one change at a time then test. |
well, i set the idle screws back to the initial setting and that seemed to clear the problem up(they were both set WAY out so i guess the fact that the idle system was unbalanced may have had something to do with it). I went to www.holley.com and looked at some of their onine manuals and got some good info from there. Ill probably check out autozone this weekend and snag up a vacuum meter and make some adjusments and see what I come up with. It does stutter a good bit when i take off from a stop. but i think i found the fix on the website. thanks for your replys.
The first thing I think about when someone posts these symptoms is that the valve springs are toast. Of course, I could be wrong.
thanks jeff, and tech
I had a similar problem with a 68 I had backin HS. I remembered my dad telling me the only problem was that theflaps were stuck open. (It was alot worse with the 68). I'll definitly check it out tommorow.
| holley carb backfires threw carb | talleyho | Engine | 61 | 05-25-2011 10:03 AM |
| Holley Carb Gas Leak | 64Joker | Engine | 21 | 07-18-2010 02:28 PM |
| Edelbrock or Holley Carb. for my street/strip Truck | anthony4401970 | Engine | 12 | 02-26-2008 12:03 PM |
| Demon or Holley Carb for 306 Ford? | Dino Boreanaz | Engine | 10 | 12-09-2006 06:04 PM |
| Holley Carb Tuning | Coleman396 | Engine | 4 | 07-19-2003 10:03 AM |
