Holley carb jetting, help please... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2003, 03:10 AM
New Member
Post Holley carb jetting, help please...
Hi,
Is there some easy ways to find good jets for my holley 650cfm double pump?
From carb to bottom:
Torker II intake
milled 882 heads some porting and matching done
steel gaskets slight dome head pistons (comp ratio 10.5:1)
289/298 degrees and .475" lift with 1.5 lifters, hydraulic lifters.
3200rpm stall converter.
Engine is at lightened Blazer K5 that is used for sand hill/pit racing. Tyres are 35" Boggers or 33" paddles. Front and rear difs are welded.
My use is way much different than on street or strip, but still I think engine power and tuning is the same.
Thanks
Jare from Finland
Old 05-24-2003, 08:06 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
The best way I have found is to use an O2 sensor and meter. There are several threads on this forum that discuss this topic in detail.
http://www.bob2000.com/carb.htm
