Holley carb kits, what's the difference - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2007, 06:16 AM
4t64rd's Avatar
Hoodlum
The Summit website list 3 carb kits for my 4160; trick, renew and fast. I understand the trick kit has lots of extra parts for tuning the carb and updating some parts, blah, blah, but what is the difference between a fast and renew kit?
Old 12-17-2007, 07:46 AM
31 five window
Last journal entry: Moving along with patch panels.
The renew kit is a more complete kit, it has more new parts for a more thorough rebuild such as the power valve not listed in the quick kit.
Old 12-17-2007, 08:02 AM
302 Z28's Avatar
Be wary of house brand carb kits, especially for a Holley carb. They are not all created equal. There are only several brands of kits I will even consider for a Holley rebuild, one of course is the Holley brand. The second is Borg Warner. Some have told me the NAPA brand is also a quality kit. I cannot tell you how many problems I fought before I started using quality rebuild kits, it just isn't worth it to skimp here. There is no way I would use anything less.
Vince
Old 12-17-2007, 08:26 AM
malc's Avatar
Born To Be Mild
I just got me a couple of books on Holley carbs and one thing noted was,
best to buy the Holley rebuild kits and as for power valves ONLY Holley.
I have just cured a problem with my carb, a BG, which turned out to be the power valve.I donīt know who makes the power valves for BG but now mine has a Holley.
As Summit donīt carry BG stuff anymore Iīll be buying Holley rebuild kits as well.
Old 12-17-2007, 08:28 AM
get the reuseable blue bowl gaskets. mine have lasted a while. if you have a vacuum secondary carb, you will have to match up the power valve. you want that fuel and air door thing happening right! also timming! get a good vacuum advance can in the dizzy, make sure that curve is spot on.
the old v8 350 performer package(.420 cam and intake) will scream, and lay rubber tunned right.
cruising, my cars had 50+ degree total advance at idle cruise( idle-2500rpm). that is good.
Old 12-17-2007, 09:08 AM
1952_Chevy_Panel's Avatar
Money pit
I recently rebuilt a 80457 which is a 4160 style carb. Make sure you get the right HOLLEY kit by using the number on the choke tower. I believe what they gave me for mine was a Holley TricKit, and it had every part I needed plus a few. Around $30 bucks.
Old 12-17-2007, 10:35 AM
malc's Avatar
Born To Be Mild
This Trick Kit from Summit is almost $100, canīt say it isīnt complete though.
Old 12-17-2007, 11:52 AM
Money pit
I must have bought the Fast Kit.
Old 12-17-2007, 01:15 PM
malc's Avatar
Born To Be Mild
I bought HLY-37-485 and four HLY-108-200 as an emergency kit.
Old 12-17-2007, 05:05 PM
Malc,
Be careful using a Holley kit on your BG carb. Depending on the model the gasket between the baseplate and main body are different.
Old 12-17-2007, 11:59 PM
malc's Avatar
Born To Be Mild
Thanks for the tip, Iīll check īem before I use īem.
In fact I do have a BG rebuild kit, Iīll check one from the Holley against the BG.
Old 12-18-2007, 02:31 AM
malc's Avatar
Born To Be Mild
Originally Posted by TechGuy
Malc,
I just checked, in the kit I bought there are four of those gaskets, all a tad different.
There is one that will fit my needs.
This kit also contains three power valves.
Old 12-18-2007, 07:06 AM
Cool. Just match one up to the gasket that's already on your carb if you change it. If you don't have the right one, you should be able to elongate a couple of the holes to make it work.
Holley (ProForm) Carb Problem leejoy Engine 30 04-01-2011 11:36 AM
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 02:28 PM
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
Holley carb gasket vetteman Engine 1 10-28-2006 04:40 PM
Identifying TriPower Holley Carb Setup 66 CT Stang Engine 5 09-07-2006 12:17 PM
