holley carb mainjet size - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2013, 01:31 PM
i have a 307 chevy enginge and my question is dose anybody know what main jet size to use i have a holley 600 cfm the jets in it right now are stamped with the number 49 and they are way to small i drilled them up and that made the car run better but would like to find the right size
the motor is original as far as i know
Old 07-08-2013, 01:46 PM
techinspector1's Avatar
Wiki Edits: 326
Basic Holley Carburetor Information
Old 07-08-2013, 06:58 PM
Richiehd's Avatar
JS-70
Wow 46s!! We don't normally drill jets, even if it makes them bigger, they don't flow properly.
Get a couple sets of jets Summit has them. Id start with 71 or 72s up front and maybe 74s in the back. Make sure you have a good power valve too. Stock probably 65
Old 07-08-2013, 09:46 PM
vinniekq2's Avatar
jets
I think 71s are a little big,I might be wrong though?
Old 07-08-2013, 10:39 PM
Wiki Edits: 326
You are correct according to the link I gave the OP.
Old 07-09-2013, 12:43 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
From here: Holley lists the Holley 1850 (600 cfm vacuum secondary) as having 66 primary jets and a 134-9 secondary metering plate which is equivalent to about a 64 jet (orifice in plate is drilled to 0.067).
Old 07-09-2013, 01:55 AM
thinwhiteduke's Avatar
Living In The Past
That's what I heard..
Duke
holley carb jet size to elevation ratio mazdaRx7 driver Engine 2 03-16-2010 10:26 AM
Holley Size Chevstang Engine 2 09-22-2009 08:21 PM
help please what size is my holley ElCa/monty Engine 1 05-12-2007 06:10 AM
what size holley should I use bracketeer Engine 10 01-16-2005 09:49 PM
Which size Holley Carb bigjoedo Engine 34 01-06-2003 03:12 PM
