Holley carb not running right - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2012, 08:12 PM
Hi folks, I believe I have either a 600 or 650 holley vacuum secondary on my 355 small block. I did mess with the idle air screws once too try and fix the problem but my problem is that the motor idles at about 800 rpm for a few seconds and then it will elevate to 1000rpm and back down again.. Back and forth. Idk if anyone know about adjusting the idle air screws and how to adjust the floats..Thanks
Old 07-29-2012, 08:22 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Check if the choke is fully open when the idle jumps up.
Old 07-29-2012, 08:31 PM
bigblockragtop's Avatar
Holley has a great ech section on basic adjustments and there is a lot of stuff on youtube believe it or not.
Old 07-29-2012, 08:54 PM
Yeah I dont have the choke hooked up. And sounda good about the tech thing thanks
Old 07-29-2012, 10:14 PM
RWENUTS's Avatar
Could be advance fluctuating in the distributor. One weak spring could cause that.
To adjust your float remove the site plug on the side and adjust the fuel level so the fuel just barely dribbles out.
To adjust the air bleeds set them both at 1 1/2 turns out. Hook up a vacuum gauge to a manifold source and adjust them to get the highest idle.
Do you have your vacuum advance hooked up. And to where?
Old 07-29-2012, 11:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Before you blame the carb, set the timing curve up correctly if you haven't already done so. THEN see what the carb needs.
The carb number- usually found on the airhorn- will tell you what you have.
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
holley running rich mainejohn Engine 35 04-10-2011 03:47 PM
Holley Running Rich Silver00V6 Engine 11 12-12-2008 05:37 AM
Ruff running 340 with Holley carb in drive. Rez Engine 1 01-14-2005 07:36 AM
Holley 600, how do I know if it's running lean? hiimed Engine 3 06-15-2003 05:40 AM
