Holley Carb Problems (No Fuel and slack acc. pump) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 09:34 PM
I have a '74 Chevy Cheyenne Super I bought which had been sittin in a fence row 5 yrs. 350 bored 60 over with a Holley 4 bbl carb. Hi Rise Pro Street Dominator intake. .270 Comp Cam. TH350. Truck runs great with the exception of the carb leaking down. Checked both bowls and tightened bolts. Checked fuel pump and pump is working fine. When the fuel leaves bowls it takes a shot of ether to get it started. Don't like using ether so help! Also accelerator pump is so slack I have to ease down on the pedal to get it over the curve before it takes off so I need help with adjusting it. I'm just a 30 yr. old that loves old classic vehicles so any help will be appreciated.
Old 08-05-2010, 09:40 PM
ericnova72's Avatar
More for Less Racer
Sounds like the accelerator pump diaphram has dried out and become stiff with age, typical and common after sitting for 5 years, I'd rebuild the carb so that all the rubber parts are fresh and all the crud abd varnish is out of the carb.
Old 08-08-2010, 04:40 PM
Thanks man. I figured I was gonna have to rebuild it. Not having the knowledge to do it yourself really sucks though. But thanks again for the info.
Shooting fuel out the carb!! Hpbbster72 Engine 7 12-05-2004 01:51 PM
