holley carb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2010, 02:59 PM
i have a old carb from 10 plus years ago. i dont remember if it is a 750 or 850. the choke bell has been milled down and the only numbers i can find are on the throttle body p-32, base plate 12r-4507 bp, metering blk.11184 3. is this enough to tell the size ?
Old 12-03-2010, 03:55 PM
ericnova72's Avatar
More for Less Racer
Not with those #'s that I know of.
What diameter are the throttle plates?? 1-11/16" or 1-3/4" ?? Or what number is on them??
Old 12-04-2010, 04:33 PM
throttle -plates are 1-11/16. they have 180 stamped on them. i can post a pic. if that will help.
Old 12-04-2010, 04:37 PM
ericnova72's Avatar
More for Less Racer
If they are 1-11/16" it could be 650-700-750-800, they all use the same size throttle plate. 1-3/4" is just used for the 850 or bigger.
Is it vacuum secondary or double pumper??
Old 12-04-2010, 04:42 PM
double pumper. if it is not a 850 then it should be a 750. i only had 2 back then 1 of each. sold 1, didnt remember what 1 i stil had.
Old 12-04-2010, 04:45 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You just answered your own question then.
Cole
Holley carb question Novi Engine 20 12-06-2009 05:37 PM
another holley carb ID question tab Engine 3 09-08-2009 06:17 PM
Holley Carb FUN (for Barry Grant Guy also) PutPut72 Hotrodders' Lounge 21 10-24-2008 09:35 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley Carb Question GoneNova/406 Engine 4 06-08-2005 06:09 PM
