holley carb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2012, 07:55 PM
awert's Avatar
58/58
I'm now rebuilding my 600 CFM 4160 ( list # 9834) Holley with kit 37-720. question is, the butterfly flapper things have some rusting, all 4, where can i find new replacements or can i repair the ones in there???? Thanks......
Old 05-08-2012, 08:00 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
If you can get them out without breaking the screws and they are not rust pitted, you can just remove them and use some very fine grit sand paper or steel wool to clean the rust. Look carefully around the edges. If the rust has ate away any material, they will need replaced.
Old 05-08-2012, 08:50 PM
awert's Avatar
58/58
that is spookie the way u said "IF you can get the screws out"...but where can they be gotten? i didn't find anything on googles...btw what are they exactly called?
Old 05-08-2012, 08:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
X2 on extra fine paper or steel wool'ing them. Holley sells replacements (I believe you need 1-9/16" diameter blades- but check to be sure)- but be sure you grind off the tails of the screws where they're staked to keep them from loosening and falling into the engine (I use a Dremel, carefully).
Here is a set on eBay.
Old 05-09-2012, 12:44 AM
X3
you cant remove the screws with out grinding the staked end off. When you put the new screws back in, make sure you stake them again, they will vibrate loose if you dont.
holley carb question rockfrog32 Engine 2 01-05-2011 01:05 AM
Holley Carb. Question JamesRS Engine 7 11-08-2010 09:59 AM
Holley carb question Novi Engine 20 12-06-2009 05:37 PM
another holley carb ID question tab Engine 3 09-08-2009 06:17 PM
Holley Carb Question STBR Engine 3 09-01-2003 10:40 AM
