Holley Carb Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2007, 01:21 AM
Which would work best with a 350
Stock cam,
Stock 76cc heads,
bored 40 over,
TRW L3022F Pistons (8.9 CR)
Stock Crank
Weiand Dual Plane Intake (8004)
Holley 4312-2 or 6619-1
I found out that the 6619-1 is a 600cfm carb, but not sure on the 4312-2
Thx
Old 11-08-2007, 03:13 AM
TRLBLAZR60's Avatar
hey
found the numbers on the 6619-1 carb
70-72
307-350-402 ci
4160, 600 cfm, vac sec, auto choke, emmission carb
Should be plenty of carb for the engine that your running.
Note: all carbs need tuned for the particular application.
Sorry, couldnt find any numbers on the 4412 carb
Old 11-08-2007, 10:35 AM
If you want good MPG and power then install a Jet rebuilt, stage 1, Q-jet for 350.00 from Summit Racing.
Old 11-08-2007, 10:44 AM
302 Z28's Avatar
I agree on the QJ for mileage, however I am not familiar with the rebuilds from Summit. The Holley is not your best choice for mileage.
Vince
Old 11-08-2007, 01:48 PM
JET rebuilds them and summit sells them. I trust JET.
However, for 50 less dollars ($300), you can buy a Q-jet rebuilt for summit and yes, I would question the quality just because it's "Summits brand".
Old 11-08-2007, 07:19 PM
Mileage
For every 'truth" there is always another side - I once owned a 350 Malibu of '73 vintage. It had a "'smogged" Quadrajet and 2.73 gears (about 4300 pounds too). Doggedy thing - but a nice riding daily driver. Mileage in town was ghastly - like 10 or 11 maybe - worse in cold weather. Specially tuned for the task, it could get 20 mpg in a flat state like Iowa or Nebraska on a summer cruise. Trouble was, in order to accelerate you had to use too much throttle - and the secondary side (even after much experimentation by a more experienced GM carb guy than me) ate up the around town mileage.
So I installed an "out of the box" Holley 6619 - with the "annular discharge" boosters (also kept the 180 manifold divided). It would then accelerate nicely in traffic -and never touch the secondaries. Mileage to work went up to 15+ and on the road she once got just over 21 for a couple of tanks that included Kansas and eastern Colorado. The carb worked fine with no tinkering required and stayed on the car for 50,000 miles - and the Chevy got changed back to the "fresh" Quadrajet when I sold it.
Fact is - the Quadrajet might have worked a little better if it had more gear to work with - but the Holley made more torque within the range allowed by the primaries and the tall rear gear. What sort of gearing is in this vehicle?
Old 11-09-2007, 08:19 AM
Sounds like you had a sick Q-jet or one way out of tune.
A Q-jet is a very complicated carb and needs to be rebuilt and setup by a Q-jet expert.
Old 11-09-2007, 08:45 AM
Changed Vehicles
Nah - my buddy tuned the Q-jet by putting it on his 350 Nova and it worked fine with 3.23's and a thousand pounds less weight - just couldn't move the big car without tipping in all the time. His Nova carb wouldn't move it either.
The old Malibu had some legs on the top end - but had the aerodynamics of a brick.
Old 11-09-2007, 09:34 AM
well, my 4500 lb truck with a BBC and 3.08 gears and 28 inch tire does great with a q-jet.
I took recently off the 750 holley which was getting 8 mpg/12mpg and put on a Q-jet and got 10/15. Yes, it took some jets and rod changes and a few adjustments here and there to make it run strong. With the q-jet, I don't ever need to open the secondarys when driving around town. Smokes the tires with just a little throttle input and I'm running a LSD diff and new tires. Much more off idle torque than the holley. I have a hard time not spinning the tire off the line.
Like I said, tuning a q-jet is much tougher than a holley. q-Jet need special attention to set them up right: jets, rods, rod hangers, air bleeds, ATP, spring tensions, accel pump shaft lengths, power springs. throttle shaft bushings, ect. ect.... and a lot of times they run poorly due to crap deep inside the carb that most people don't know how to remove during a rebuild. Plus the number of rod/jet/spring combos are almost endless which greatly increases the chance of a bad setup.
Holley (ProForm) Carb Problem leejoy Engine 29 04-01-2011 12:36 PM
Holley Carb. Question JamesRS Engine 7 11-08-2010 10:59 AM
Holley Carb Gas Leak 64Joker Engine 21 07-18-2010 03:28 PM
Holley carb problem crusherdbuzz Engine 3 07-09-2006 04:12 PM
Holley carb & powervalve info Frisco Engine 9 06-25-2003 02:47 AM
