Holley Carb squirter problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2007, 01:40 PM
I just rebiult a 450 cfm holley 4160, installed it on my datsun and for some reason the squirter isnt squirting, it just drips. i read somewhere that there is supposed to be a needle and ball under the squirter, there wasnt one there when i tore it down and didnt see one in the trickit i got from holley. any ideas?? Or pics with numbers...pleeeze....
Old 07-04-2007, 03:19 PM
pump arm
I assume the pump arm is working? the spring should rest on the arm. That is probably not it, sounds like you know what you are doing.
Old 07-05-2007, 05:52 AM
arm is working and is set with .015 clearance wide open, wonder if the ball under the arm (inside) isnt seating correctly, the kit only had 2 balls in it, 1 was too big and the other was too small so i had to use the old one, the carb is old and might not be seating the ball, hmmm maybe i need to look better this weekend.
Old 07-05-2007, 01:16 PM
FiveFeezy's Avatar
Fishing poles in the hot rod!
There should be a needle under the squirter and a check ball or rubber plunger in the float bowl where the pump reservoir connects.
Old 07-05-2007, 09:08 PM
Well, took the carb off and took it to work, found the needle under the squirter, stuck in place really bad, had to soak in carb cleaner and blow it out with air hose, got it out and cleaned it up and used pipe cleaners to remove gunk, checked the ball in the pump housing, was stuck in the open position so every time i tried to squuirt it was going right back into the bowl, will put back on sat morning and hope it works, 1 other problem i found this morning, plugs 4,5,6 are grey fouled and firing orr the side of the insulator, these plugs are only 2 months old and only have about 50 miles on them. are they fouled because of fuel mixture?? i am not sure if i even have the right plugs, this used to be a fuel injected motor with electronic ign, but previous owner changed to points and carbs, had 3 webers on it when i got it but now has a 450 holley. cant find another electronic distributor for it (datsun 280z)
Holley problem camaro freak Engine 3 08-30-2006 10:12 AM
Any Holley carb gurus out there? 65Cyclone Engine 14 10-26-2004 05:38 PM
670 holley carb problem jajeff22 Engine 3 03-19-2004 06:49 PM
Holley Carb Tuning Coleman396 Engine 4 07-19-2003 10:03 AM
holley carb problem mshellw Engine 5 03-17-2003 05:01 AM
