Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-19-2004, 10:42 AM
subman17's Avatar
subman17 subman17 is offline
Holley Carb/supercharger Question
I am installing a 144 blower on my chevy 350 and I had a question regarding the carb. I understand that the carb must have a boost referenced power valve, but is there anyway to convert a non blower carb to this set up? I have a 1 year old holley carb that I am very happy with, and I hate to have to replace it at a cost of $470. Thanks! Also, are there any Edelbrock carbs for blowers, I cant find any specifically noted for it in my catalogs.
Old 05-19-2004, 11:05 AM
orangef4 orangef4 is offline
re: Holley Carb/supercharger Question
You can do some modifications to your carb to boost reference the power valve, but it does require that you remove the throttle body from the carb. Basically, you plug off the passage in the throttle body that feeds the power valve. Then drill a hole through the side of the throttle body that intersects the original passage, and insert a small tube that you can hook a line to. There is a book, I think it is Super Tuning and Modifying Holley Carbs, that covers how to do it. You might be able to find info on the net, too.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
