holley carbs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2013, 11:11 PM
holley carbs
holley carbs, 6929 vs. 3310-2; used on a 1975 gmc 6500, tandum axle, 2 transmissions, 5 main 4 aux, low gear ratio 732 ? . pro & cons. total weight, truck and load 44,000 lbs. getting ready to rebuild one or the other.....
Old 05-07-2013, 06:56 AM
vinniekq2's Avatar
Is this a resto project? 427 tall deck?any changes to the engine? the 6929 sounds like what it came with
The Following User Says Thank You to vinniekq2 For This Useful Post:
pat mackey (05-07-2013)
Old 05-07-2013, 03:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the 6929 has all the governor paraphernalia on it I'd use the 3310 tuned for the engine/truck.
Either way, tuning a good advance curve in the distributor can make a lot of difference, especially if it's still set up stock.
The Following User Says Thank You to cobalt327 For This Useful Post:
Holley carbs?? Help!! gofastz Engine 7 06-01-2010 03:47 PM
holley carbs bugandbj Engine 6 11-30-2007 08:27 PM
Holley carbs. Slant3 Engine 3 08-16-2004 05:42 PM
Holley Carbs VS. Edelbrock Carbs. KeithB123 Engine 3 01-12-2004 10:42 PM
holley carbs monte Engine 2 04-24-2002 04:56 PM
