Holley Carbs VS. Edelbrock Carbs. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2004, 06:23 PM
My main question is concerning the jet sizes. I just read that one of Holleys750 cfm Jet sizes were : Primary-73, Secondary-73.
My Edelbrock750 cfm has : Primary jet is .113, Secondary-.107.
Am I comparing apples to apples here? Notice my punctuation or the way I typed out the jet sizes ( They are both right from the book ).
If I am comparing apples to apples....then the Edelbrock has alot more push than the Holley?
Old 01-12-2004, 06:38 PM
Jmark's Avatar
Just remember that the Edelbrock has metering rods inside the jets, reducing the inside diameter of the orifice. To get an accurate compairson, you need to figure the actual surface area of the holley jet, then figure the area of the jet of the Edelbrock, MINUS the area of the rod tip.
Bigger is not better in all cases. Its all a matter of how much gas you need.
Old 01-12-2004, 06:50 PM
That was a great reply.
Are those 2 carbs similar in performance? Is theere enough info provided?
Old 01-12-2004, 10:42 PM
MI2600's Avatar
Member# 3287
I thought the stock (factory) jetting for a Holley 750/780 was 72 primary and 78 secondary. Thinking is always dangerous.
This type question has been tossed around a lot here. It boils down to personal preference. Some feel the Holley has more "tuneability". But, I like the simplicity of the Edelbrock. I've got a 780 Holley on a 383 and a 750 Edelbrock on the 406. I'm not too worried about performance at the track. I'm just a street driver.
My $.02
