Holley Carburetor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2010, 12:03 PM
Holley Carburetor
Have a 1986 Ford Bronco with a 5.8 hi out put 4v engine.
Has a Holley carb. Trying to find out the carburetor model and cfm of it.
Anybody help out.
Thanks
Old 11-26-2010, 12:19 PM
It is a Holley built for Motorcraft 600 CFM. Not a bad carb the idle mixture screws are 4 corner and in the baseplate. You will have to uncover them if they have not been already.
Mike
Old 11-26-2010, 12:54 PM
bigdog7373's Avatar
Of course it's fast
Is it the original carb? I'll run the numbers for you if you post 'em.
Old 11-26-2010, 12:58 PM
Holley
Thanks Mike, but what would the model be 4150, 4160, 4180. It still has all the pollution garbage on it. and is a automatic and how can you tell if the electric choke has power to it.
Old 11-26-2010, 04:48 PM
bigdog7373's Avatar
Of course it's fast
If the choke closes on a cold start then it is working. Any numbers on the carb? Post em on here.
Old 11-26-2010, 05:29 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If it's orignal equipment it should be a 4180 carb and the kit number is holley 3-1346 , If this is what you have anyway. # should be like this 50264-1 and the other is something like this E5TE 9510. Like i said if it's orginal carb it would be a 4180 carb that's what came on those windsor engines. JMO
Cole
Old 11-27-2010, 12:53 PM
Holley
Thank You for the info. It really helped out. It is the orginal carb that came with the Bronco XLT. I use it for a daily driver to and from work and to the grocery store.
Having problems with the electric choke not opening after warm up in morning. there is a wire going to the choke but doesn't seem like theres no power coming from it would that keep it from working properly.
The numbers I found on the carb are on a stamped blue tag E5TEZBA5H8!
Holley Carburetor Identification 64Joker Engine 8 08-16-2010 05:38 PM
Holley fuel pump, return line or not to return line??? JD's camaro Engine 1 07-16-2010 05:17 PM
Holley carburetor help xtrem mecanic Engine 2 06-08-2010 12:36 AM
Fuel efficient carburetor AmericanMuscle74 Engine 7 04-12-2010 07:36 AM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 09:55 PM
