Holley Carburetor Identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2010, 05:09 PM
64Joker's Avatar
64Joker
Can someone assist me in identifying a Holly carburetor model?
Do I look for stamped numbers on the carb?
Also, how can I tell if the intake manifold is aluminum?
See attached pics.. Thanks in advance..
Year: 1964
Make: Chevrolet
Model: Impala SS
Engine: 327 cu. in.
Intake manifold: Edelbrock
ID:	47508   Click image for larger version
ID:	47509   Click image for larger version
ID:	47510   Click image for larger version
Old 08-16-2010, 05:17 PM
bigdog7373's Avatar
Of course it's fast
manifold is aluminum. Carb looks like a 600 or 650. Look for numbers on the carb.
Old 08-16-2010, 05:20 PM
SSedan64's Avatar
I agree^^
A magnet wont stick to Aluminum.
Look for 1850 etc.. on the front right of the Choke Horn.= 600cfm w/Vac. Secondary.
Old 08-16-2010, 05:26 PM
ericnova72's Avatar
More for Less Racer
Carb says LIST-1850-3(??, not sure if it is a 3 at the end), it is a common performance replacement 600 cfm Vacuum Secondary, square flange, 4160 model
Old 08-16-2010, 06:19 PM
64Joker's Avatar
64Joker
Follow-up
What products are out there for cleaning/polishing the aluminum intake manifold without removing it? Thanks for all your help....
Old 08-16-2010, 06:21 PM
bigdog7373's Avatar
Of course it's fast
They make this stuff called soap and you combine it with water.
Old 08-16-2010, 06:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Forget polishing, but you CAN use Gunk engine degreaser. Follow the can directions. You can scrub bad spots w/a toothbrush or some of those small wire brushes.
Old 08-16-2010, 06:35 PM
SSedan64's Avatar
Gunk may darken the Al.
Super Clean, Greased Lightning, Purple Crap etc.. works good on Al.
Old 08-16-2010, 06:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I've never had that happen.
Quality control issues with Holley Street avenger carb's? eric32 Engine 20 12-09-2016 07:25 PM
Older Holley 4150 and 700R-4 TV Cable Problem Solved -- Maybe hduff Transmission - Rearend 6 08-20-2016 06:08 PM
Holley Carb FUN (for Barry Grant Guy also) PutPut72 Hotrodders' Lounge 21 10-24-2008 10:35 AM
Holley throttle body Kevin45 Engine 1 06-10-2005 12:46 PM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 03:53 PM
