Holley carburetor Identification help.
25K views 9 replies 6 participants last post by  FmrStrtracer
Hey guys, I got a carburetor from a friend a while back and was wondering what kind it is, and if it's worth anything? I wanna sell it to fund buying another carburetor for my 65' AMC Marlin.
I've seen a couple threads with carbs with mostly matching numbers, but there was a couple different numbers so I figured I would start a new one...Sorry if I posted in the wrong section or if starting a new thread was the wrong thing to do.
Choke throat Has
LIST - 6210-3
1439
Directly below that it says 4261
Top of Primary "metering plate" says
7866
6210
top of secondary "metering" plate.
L62103 8521
8522
the base plate has "12R-5395B"
and that's all the numbers I can find, here's some pictures hope it helps.
Thanks in advance guys!
See less See more
3
#4 ·
Wow that's allot more than I thought it would be...What do y'all think I should list it as? I was thinkin about $300 OBO or is that way too much? it's in Usable condition I would say, inside is clean and was taken off a running vehicle about 6 months ago.
Jesse94 said:
Hey guys, I got a carburetor from a friend a while back...
The Holley 6210 was made to be a direct replacement for a Rochester Q-jet. They were emissions compliant and you'll notice there's no external float adjustment and the location of the fuel inlet is the same as a Chevy Q-jet.
Unfortunately, they are not in demand. I doubt you'll be able to get much more than a core price for it the way it sits.
You can advertise it as a Holley 650 cfm model #4165, List (part number) 6210-3, spreadbore Q-jet replacement carb.
Good luck.
#8 ·
Good luck.
FYI- They also made an 800 CFM version. They work great on light cars with manual trans.
#9 ·
There are literally dozens of different part numbers for Holley spreadbore carbs: some emissions legal and some not, there are 4165 and 4175 models, 650 and 800 cfm, single and double pumper, etc. But the 6210 the OP has is a 650, just so there's no confusion.
