Holley Contender 300-36 SBC intake questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2008, 03:44 PM
I have a Holley Contender intake on a mostly stock 350. It came with the car and I don't know how old it is. It's a 300-36 which is the same model no. as the current high rise strip dominator. But that doesn't mean it's exactly the same. I know that Holley and Edelbrock went to a smaller cross section high efficiency runner in the '90s. Anybody have any idea when that happened, and what I should look for to find out what I've got? I know that the newer manifolds have 1.99" x 1.14 inch ports, but I'd like to see if there's any way to tell without having to pull the manifold just to measure the ports.
Basically, I'm going to swap to better heads. I'm thinking AFR 180s. I'm trying to decide if my manifold is going to be the new chokepoint or if it can flow all the intake charge the heads can handle.
I'm thinking of just port matching the runners and installing a lifter valley cover to keep the manifold cooler and seeing if I can get most of the benefits of the newer air gap type intakes.
If I do need/want to get a new manifold, does anyone know where I can get independent info on the weiand stealth air strike? There are plenty of articles and dyno tests about the Performer RPM air gap, but I'm not sure if that's because it's the best or if Edelbrock just has better PR and more advertising dollars.
Thanks for any info.
Old 03-13-2008, 05:19 PM
F-BIRD'88's Avatar
Yada Yada Yada
The holley intake #300-36 is essentually a knock off of the old GM factory 1969 1971 Z-28 302 LT-1 350
The manifold has not changed. The marketing over the years has. Different names cast onto the same manifold.
It will work very well with AFR heads. Port match it, bolt it on a go.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
406 sbc questions tiresmoke55 Engine 13 04-26-2007 10:50 AM
SBC 283 intake & Carb Swap Problems iceman_77 Engine 4 02-13-2007 05:49 PM
Edelbrock Torker Intake Questions boneyard Buick Engine 2 03-19-2006 09:01 PM
cam and intake questions RedRocket Engine 2 11-11-2002 10:41 PM
