Holley or Demon carb(part 2) - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2004, 02:45 PM
stinky jinx's Avatar
Searching for horsepower
I called Demons tech line and asked about whether or not to install a spacer under their "race demon" carb and they suggested a 1 inch 4 hole spacer....I want low end torque.......does anyone have any experience with this?
Old 05-28-2004, 04:45 PM
Race Demon?
I thought you were looking for a carb for a mild 350 engine.
Are we on a different engine here?
Old 05-28-2004, 05:03 PM
stepside454's Avatar
thats what I was thinkin.
Stinky, what RPM do you plan to run your 350 to ?
Old 05-28-2004, 07:08 PM
chianesi's Avatar
Never Give Up
The spacer will give you better fuel atomization and create more low end torque, but I hold the opinion of the rest of the guys...What are you trying to do with the 350?
Old 05-28-2004, 08:32 PM
holley or demon
Sorry.......I meant "road demon".......this is the same mildly built 350. I just wanted more low end to pull this thing up out of the hole. I am running a posi with 343's, but it still is a little sluggish off the bottom. Just wanted to know if the spacer is takes away low end and if so why did "Demons" tech guy tell me I needed one?..............jerry
Old 05-28-2004, 08:39 PM
DoubleVision's Avatar
Open spacers kill low end power in favor of upper rpm power, 4 hole spacers help low end power due to higher velocity. what port is your vacuum advance connected to, a full time manifold vacuum source or ported? it should be on a manifold source, if it`s on ported the engine will feel like a slug in the low end.
Old 05-29-2004, 12:26 AM
I am not using the vacuum advance........I am using breaker less distributor along with a Mallory Hyfire VI electronic ignition......jerry
Old 05-29-2004, 11:27 AM
If the vacuum advance is available I would recommend using it.
You are not running a race car and all street driven vehicles can benefiet from a vacuum pot on the distributor.
I made a custom 4 hole spacer for my road demon and while I am still playing with the jetting it has the power down low.
So yes I would recommend a 4 hole spacer for it.
