Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley discharge nozzles
Old 08-22-2008, 09:18 AM
kleen56's Avatar
kleen56 kleen56 is offline
Originally Posted by T-bucket23
25 is real small, most baseline at 28 or 33.
Also check your accelerator pump for zero lash
I've heard several ways of checking zero lash on the accelerator pump. I was told to WOT, then with a 1/4 in wrench push down on the accelerator pump arm, then measure the clearance between the arm and the linkage. That should be at .015 with a feeler gauge. Is this the right method, or is there a better one?
