Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley Dominator flange pattern
Old 01-02-2005, 10:44 PM
Full Throttle Full Throttle is offline
I have the enderle linkage on mine which was fairly easy to hook up. It is very adjustable with splined shafts so it doesn't slip. I have 2 ea 850dp on mine which I sent to Rupert racing to build. He is very good with the holleys and nailed my setup the first time. When you have two carbs you build them with smaller idle circuit flow per carb because you are idling with 2 carbs now. He already has a big knowledge base on peoples setups and can probably get your right the first time also. I just sent mine back to him to refresh them since I'm putting this motor back in my car. He saved the build sheet on mine from about 5 years back. I even put the idle screws right back to the same position he had them in after I tried to adjust them. It idled great and ran a 6.30 in the 1/8th.
