Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley Dominator II Intake
Old 01-13-2011, 07:58 AM
matts37chev's Avatar
matts37chev matts37chev is offline
& matts38chev
Last journal entry: Try again
Originally Posted by DoubleVision
I don`t know why that comes up so much. Even so the Edelbrock performer is a Spread bore design, it has dual bolt patterns to accept both Square and spread bore carbs. A holley or Eddy carb will bolt right on and it don`t need a adapter plate. All it needs is the thin metal plate inbetween two gaskets that assures it covers the opening where the plenum spreads out for a spread bore carb.
i always forget that those intakes are dual bolt pattern allowing the use of both style carbs
you can use that intake
