Holley Dominator II Intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2011, 07:10 PM
Brandonion1985's Avatar
Are these pretty good intakes to use with Holley carburetors on a 327 Chevy? Bought a Edelbrock performer intake few years back and didn't look at it much, just noticed its for spreadbore carbs and will not work without adapter plate. Was just wondering if anyone knew much about Dominator II intakes for street driving, performance ect.
Old 01-12-2011, 07:31 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
i dont know much about the holley
my standard answer is, get a edelbrock perfomer "RPM air gap"
http://www.edelbrock.com/automotive_...r_gap-sb.shtml
Old 01-12-2011, 07:58 PM
I found someone who has the holley one was looking to trade one I got for it. Just was wondering if anyone has used them. Heard air gaps are good too, will look into those also
Old 01-12-2011, 08:09 PM
I don't understand?
strip dominator or street dominator?
Old 01-12-2011, 08:12 PM
Pretty sure its the street version dual plane intake.
Old 01-12-2011, 08:17 PM
Wiki Edits: 31
If the P/N is 300-36 then it is pretty much the same as the 302 CI Z/28 manifold and would be about perfect for the 327.. They have been called Contenders also, but also Street Dominator II. P/N 300-36 has always remained
Old 01-12-2011, 08:23 PM
I don't understand?
that would be good - do it, trade is always a great price
Old 01-12-2011, 08:52 PM
I think it is that one will have to ask part number here are a few pics if that helps id it, thanks again guys
http://i84.photobucket.com/albums/k3...eb/Car/in3.jpg
http://i84.photobucket.com/albums/k3...eb/Car/in2.jpg
http://i84.photobucket.com/albums/k3...eb/Car/in1.jpg
Old 01-12-2011, 09:03 PM
I don't understand?
i think that would be ok
i think you could do better with the RPM Air Gap
but that "trade" price is hard to beat
Old 01-12-2011, 09:20 PM
Wiki Edits: 31
could be the 300-64 but the pic is blury http://www.holley.com/300-64.asp
Old 01-13-2011, 03:00 AM
DoubleVision's Avatar
I don`t know why that comes up so much. Even so the Edelbrock performer is a Spread bore design, it has dual bolt patterns to accept both Square and spread bore carbs. A holley or Eddy carb will bolt right on and it don`t need a adapter plate. All it needs is the thin metal plate inbetween two gaskets that assures it covers the opening where the plenum spreads out for a spread bore carb.
Old 01-13-2011, 03:11 AM
Bore pattern looks different to me. Here is a link to the manifold I have
http://performanceparts.com/part.php?partID=470
Old 01-13-2011, 07:58 AM
I don't understand?
i always forget that those intakes are dual bolt pattern allowing the use of both style carbs
you can use that intake
Old 01-13-2011, 11:02 AM
Do I need to get anything special for it? Also is that Holley one better for a 327 or are they about the same?
Old 01-13-2011, 11:13 AM
Wiki Edits: 31
without a part number were shooting in the dark. if it is the 300-64, it only fits '87-'95 heads. if it's the 300-36 then it's probably a better intake, but it's name was more commonly called the Holley Contender.. Performer will certinly work good for a street car, but as designed it is 1 step up from an OEM cast 4bbl intake
Holley Dominator Question S10 Racer Engine 1 09-16-2008 12:10 PM
Resurected From The Dead: Holley Street Dominator Intake kuhn-77 Engine 3 01-11-2007 01:19 PM
Holley Street Dominator Intake solamisandwich Engine 5 12-08-2005 01:48 PM
Holley Street Dominator Intake ??? solamisandwich Engine 2 12-07-2005 08:59 PM
Holley Street Dominator. Skunk Engine 4 07-01-2005 02:04 PM
