Holley or Edelbrock? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2009, 10:21 AM
mattmar's Avatar
Hey fellas! Just wanted to start a friendly debate. about holley and edelbrock products. I myself am a holley fan and love their products and would never consider using anything else for mild street/strip applications. I am not a pro on the subject of carbs and such thinsgs. i just know i have never had a problem with their products that couldnt be solved with common sense and proper tuning procedures. Well thats my opinion let me know what some of yours are. thanks guys!!!!!!
Old 05-01-2009, 11:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
As far as carbs go, generally Eddys are cheaper, Holley's much more tunable, but pricier.
For max performance, Holley or Holley knock-offs are the best bet, IMO. Toilet bowls and Predators et al never seem to have put much of a dent in that market.
AFA intakes go, you see the occasional Holley, but Eddy's are much more prevalent. Whether that is indicative of the quality or performance or price, I really can't say.
Old 05-01-2009, 11:15 AM
I agree with Cobalt, you will rarely see anything other than a Holley carb or Holley-like carbs on most any serious race car, whether its drag, circle track(dirt or asphalt),offshore boat racing or any other racing venue. Just go to any NHRA or IHRA national event, or NASCAR race and see. I think Edelbrock makes far better intakes for performance than they do performance carbs, their carbs seem to be more used in mostly milder street car and cruising applications where they seem to do good for those applications.... I give one vote for Holley carbs and one vote for Edelbrock intakes as being the better choice for all out performance expectations....
Old 05-01-2009, 02:53 PM
I agree with the two post above.
holley carbs are much better than edelbrock carbs, but edelbrock makes better intakes.
furthermore.
holley electric fuel pumps suck (loud as hell).
edelbrock mechanical fuel pumps work great.
holley heads and edelbrock heads are about the same.
I do run a holley intake on my 454 because it has a square bore carb flange and was cheaper than the edelbrock performer or RPM.
Old 05-01-2009, 03:04 PM
MT71c-10's Avatar
too many toys,not enough money
Last wiki edit: Garage heating Last photo:
Wiki Edits: 13
click, I just heard a can of worms being opened. I would suggest you use the search funtion, and read through the pages of pages that have already been discussed about holleys and edelbrocks on the forum, and make your own opinion. This thread will probably turn into a head banging match, and not awnser your question. I run edelbrock on my truck.
Old 05-01-2009, 03:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'll sweeten the pot w/this gem- I've used darned near every carb out there.
Love the Q-Jet. Holley's are fine even have an Edelbrock Carter knock-off that does OK.
The worst of them all was the Thermoquad. Good idea, just plain bad manufacturing and material choice, IMHO.
Next worst was a Holley Model ?? that a buddy bought for his Pontiac 406. It had removable boosters and was built something like a Carter AFB-type carb. Was one of the first that came ball tumbled silver.
Old 05-01-2009, 05:21 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I also agree with cobalt & cnc -Dude. Holley as far as the carb goes and like the edelbrock intakes. Even though i really like my holley dominator intake on my 408 in my camaro. Just had to add that part. Cole
Old 05-01-2009, 07:52 PM
hemi joe's Avatar
loves ex cop cars
good stuff guys.i'am in the middle of deciding on a edelbrock performer intake 3706 or holly 300-64 for my caprice 5.7 350.still not sure.....JOE
Old 05-01-2009, 08:23 PM
powerrodsmike's Avatar
Wiki Edits: 161
I prefer Holleys, and have always had better luck getting a Holley to work right than an Edelbrock, especially on anything with more than a moderate cam.
I never had the problems with Holleys that most complain about, like leaking bowls and too many adjustment variables, and I'd rather have a stand alone power valve that will blow out than play with springs and needles. ( the Spectre blow out prevention kit needs special attention in order to get it installed, the drills that come with it are just plain WRONG)
That being said, I swapped the 650 Holley spreadbore on my Blazer for a Edelbrock , only because I was too lazy to rebuild the Holley...when I rebuild the Holley, the Edelbrock is coming off and going back in the carb pile...
I did replace the thermoquad on my 440 dodge motorhome with a carter AFB (looks like a edelbrock/weber/carter... wth is the diff?), and after I modified it to play nice with the stupid Dodge EGR system it works ok. It even passes smog.
I'm not super carb tuner guy, but still like Holleys over Edelbrocks.
Later, mikey
BE different....ACT normal.
Old 05-01-2009, 08:34 PM
kleen56's Avatar
I've run both carbs as well and no complaints with the Edelbrock (600 cfm) carb. It's a matter of choice. Edelbrock is reliable, and is a great carb for a daily driver or cruiser. If you want your engine to wake up and perform on the street or strip, it's not going to happen with the Edelbrock. I tried everything to make the carb run at its peak performance and still felt like I was running a two barrel carb. I switched to the Holley and it was like day and night. My friends thought I switched engines. The engine came unglued like it had four barrels. The Holley is much easier to adjust and you don't need springs/ rods and a computer analysis diagram on making the carb richer or leaner. I gave my Edelbrock to my cousin for his daily driver. Edelbrock will save you gas, because you rarely put your foot into it. It's a good cruiser carb! I've noticed a majority of cars that have serious horsepower at shows or the track are running Holley's. That might give you a clue?
Old 05-01-2009, 08:52 PM
Greg T's Avatar
www.krusinklassics.net
Never had a problem with an Edelbrock and it remains my carb of choice. Very simple tuning and they just plain run. My 750 on my modded ZZ4 even made 8 more ponies than the chokeless Holley that was on there.
Old 05-01-2009, 09:40 PM
DoubleVision's Avatar
I stick with Quadrajets. For a street car, a correctly tuned Quadrajet it hard to beat. Small primaries make for fuel injection throttle response and sensitivity. The huge secondaries are there when maximum air flow is needed. Quadrajets are "Air Dam" carbs, meaning they give what the engine demands in air flow. Tuning a Quadrajet is a little more tricky than a holley but the rewards are greater. But I agree, if easy tunability is what your after a Holley is the way to go. I personally hate Edelbrock carbs. Many look at a Quadrajet and are intimidated, so comes all the foul names given to it. However, lastly I`ll say this as a fellow member of this board has said so many times, a carb is as good as the guy tuning it.
Old 05-01-2009, 10:31 PM
jgh64pkup's Avatar
Last journal entry: new et streets
whats wrong with the holley electric pump
its not too noisy your exhaust is just not loud enough
Old 05-02-2009, 07:01 AM
mallory fuel pumps are the electrics to use. quiet as a church mouse.
I threw 2 edelbrocks in the thrash. both vapor locked and both developed a sticky throttle due to the rubber accelerator pump seal digging into the pump cylinder. cheap design. I guess you get what you pay for.
Old 05-02-2009, 07:05 PM
cranky1's Avatar
Just stuck
[QUOTE=cobalt327]
The worst of them all was the Thermoquad. Good idea, just plain bad manufacturing and material choice, IMHO.[QUOTE]
Oh man. The best street carb I've ever had was a TQ. Ya, they have their problems but once you learn them, they run great and are not hard to tune on. The biggest problem with them is the phenolic resin main well and adjusting the secondary air door if you don't have the correct tool and most didn't. The main well was subject to warping especially if the engine was overheated but it did keep the fuel cooler. Anyways, a lot of guys run pretty fast in Nostalgia Super Stock with other than Holley. If your car didn't come from the factory with a Holley, you can't use one and most of those old cars didn't. I also like Holleys for racing but when you can't use one, ya gotta make do. Mopars used the AFB on a lot of their cars and they can be made to run pretty dang good. One Holley model I didn't care for was the one that came on some slant 6's. Can't remember the model but it was a single barrel and the float bowl only had 2 screws and most of the time, someone overtightened them making it almost useless.
Edelbrock v Holley tjs1968 Engine 5 10-09-2007 06:44 AM
Holley vs Edelbrock johnny7 Engine 10 01-21-2006 09:19 AM
Holley or Edelbrock? Is 600 CFM enough Jag Daddy Engine 12 05-05-2004 12:29 AM
Where to find TV adapter for Holley or edelbrock? Destructo Transmission - Rearend 12 11-28-2003 01:14 PM
holley or edelbrock nd500 Engine 1 02-22-2003 08:23 PM
