Holley electric blue fuel pump noise??
Hey guys, just finished wiring up my BRAND NEW holley electric blue series fuel pump. The fuel lines are not connected yet but I wanted to make sure all my wiring was fine so I gave it power to see if I could hear the motor turn on quickly then I would shut it off. Well it hasn't made any noise and all wiring is good, it is getting a full 12 volts for sure I have tested with my voltmeter and the ground is clean as could be.
I guess my question is do these pumps make virtually no noise and it is actually turning on because again I can't hear a darn thing!! Even if I hook it straight up to the battery I don't hear it make any noise. Please help.
Hook the fuel lines up and get some pressure in the system to develop a load on the pump and see if you can hear it then. They are loud, unless Holley has made a dramatic change in the three years since I bought my most recent one. I've had a few on various vehicles over the last 10 years or so and all of them were fairly noisy.
The only problem I ever had was when I didn't connect an external voltage regulator to the alternator and I drove around for a week or so with the alternator pumping out as much as 22 volts. Needless to say, the electric fans, ignition box, headlights and fuel pump did not like the extra voltage very much. ![]() If you have an extra person handy have them stick their finger over the inlet to see if you get any suction when you turn it on. |
Will it damage the pump at all to run it without pumping fuel??
I have my holley blue pump in the trunk, and I can hear it over the exhaust and the noisy gear drive under the hood.
They make a lot of noise. To say the least. However they might not start making alot of noise until you actually have fuel. But you will definately know that it is on, regardless. |
would it matter that my pump is moutned sideways?? (Holley recommends mounting it with the motor side on top) I am maybe thinking that there is some sort of integral safety switch that won't allow it to turn off unless the pump is upright (incase the car flipped over or somthing).
| electric fuel pump question | sexypizzaman | Engine | 19 | 06-07-2009 04:12 PM |
| Help - my fuel pump is leaking | KENMO | Engine | 10 | 07-01-2007 12:39 PM |
| Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? | MuscleTruck | Engine | 5 | 05-23-2003 12:36 AM |
| electric fuel pump | amerikian | Engine | 2 | 05-02-2003 07:20 AM |
| Holley blue fuel pump install | edubois | Engine | 7 | 02-23-2003 06:58 AM |
