Holley Electric Choke Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2011, 04:15 PM
Hello all. I am trying to hook up my electric choke on my Marine 600cfm Holley. Problem is trying to find an ignition source in the engine bay. Everything on my boat is run through separate circuit breakers and there is very little to choose from as far as an ignition source. I know running off the coil is bad for life. But, what if I were to run a standard 12V 4 post relay and only use the coil as the ignition source? Shouldnt provide any draw since it is only being used as an excitation voltage right? Thanks guys!
Old 06-29-2011, 09:19 AM
There's a much easier way to wire the choke. Use a Standard Products PS64 oil pressure switch and wire directly from the alternator or other +12V source. Since the switch only makes contact when the engine is running and there's oil pressure, using a 12v source that's always on isn't a problem.
Electric choke wiring streetrodderbn Electrical 3 06-12-2009 05:48 AM
electric choke wiring jakeleg Electrical 50 02-14-2009 06:49 PM
Holley 570 cfm electric choke 1969 Camaro Engine 3 07-13-2008 11:08 PM
Holley Electric Choke gawdzilla Engine 15 07-12-2005 09:17 AM
Holley Electric Choke daveh Engine 3 01-26-2004 07:26 PM
