Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-20-2008, 06:24 PM
yragat yragat is online now
Holley float adjustment
I was wondering,if U have an electric fuel pump,can U adjust a holley float with just the pump on and the engine not running? There is no fuel in it yet If I take the site plugs out and turn the pump on can I make the adjustment without the engine running?
Old 05-20-2008, 06:32 PM
Jmark's Avatar
Jmark Jmark is offline
HR moderator dude
re: Holley float adjustment
Yes you can. I'd first suggest lowering them a turn or two before starting up the pump, just in case.
Lets just hope the "change" that we think we are getting does not end up being just "chump change"!
Old 05-20-2008, 06:33 PM
Thank You!!
Old 05-21-2008, 09:29 AM
CarbGuy CarbGuy is offline
You actually do need to have the engine running to adjust the floats properly if you're going by the sites on the side of the carburetor.
If your float get too high, there is no way to lower the level since there is no fuel flowing through the carburetor. Plus the pressure inside of the carburetor is different static to running which can vary your float level.
Old 05-21-2008, 03:37 PM
BUT would doing it without the engine running put it somewhere near the level as when it is running?
Old 05-21-2008, 03:52 PM
It won't be the same... It might be OK for a starting point, but you'll still need to adjust it.
Old 05-21-2008, 03:53 PM
sam-missle sam-missle is offline
as jmark said lower the float level before you start, remove the plug and adjust the level. the float level shuts the needle and seat. weather fuel is flowing thru, the float level controls when to stop fuel flow. start the engine and see if the level changed. which i doubt very much.
sam-missle
Old 05-21-2008, 06:25 PM
Jmark's Avatar
HR moderator dude
sam-missle
Thank you!!! Atleast one other person has apparently had one too many engine fires from trying to set the floats with it running!!!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Holley float adjustment"
Holley carb - Float bowl adjustment gilby246 Engine 8 01-16-2007 05:39 PM
Holley Carb Brass Float Adjustment leejoy Engine 2 04-14-2006 09:02 PM
holley float adjustment ponch Engine 3 08-29-2003 06:50 AM
4175 Holley Float Toe adjustment 7t7buckskin Engine 2 07-24-2003 07:52 PM
Holley Float Adjustment Help MI2600 Engine 2 02-23-2003 05:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
