Holley website never had this carb listed as it's sold. It has different fuel bowls and floats. The bowls have the fuel lines going up into them at a 45' angle and the floats are about 1" fat, 2.5" long. If you google 4160 fuel bowl it's the most common image.
http://www.holley.com/data/products/.../large34-2.jpg Last edited by bubbahotep; 08-02-2010 at 10:04 PM. Reason: Pic link added |
Side hung float bowls used the spring.
Center hung floats do have a spring, but it isn't a coil type spring like shown in the side hung bowl pic that Cobalt posted. It is a single loop spring with two 1/2" long legs, the loop fits around the float pivot pin and levers between the float arm and the float mounting bracket.
If yours is missing, you can get a replacement in Holly Carburetor Float Kit #20-105. Costs $9, doesn't come w/the float, obviously. If you just need a couple springs, PM me w/an addy and I'll get you out a couple, gratis.
Thanks everyone. I knew the spring type but not the float name and every site I saw showed the spring. Every holley book I have matches my carb and shows the spring. Holleys website is the only place that DOESNT show my carb although it seems to be a common configuration.
I don't know why yours would have been left out, but if you were having a problem with the carb running rich for no apparent reason, that could very well have been the cause.
Every time the carb is jounced or tipped, w/o a spring the float will momentarily drop. This allows more fuel in every time this happens. Over a course of a set of stutter bumps or pot holes, this will allow the carb bowl(s) to fill to the point of overflowing through the vents into the engine and could cause stalling or at least very rough, pig-rich running conditions. |
Cobalt: sometime in the 90's I had changed the power valve and apparently I left the spring out. Oops. I've had random stumbles from the carb at hard stops over the years and always thought it was just a fact of life. I wouldn't doubt some sputters were from this. Sputters were always at low speed usually with no throttle, just idling to a stop or around a corner. Every now and then I'd get a near stall when going from reverse to drive and would blip the throttle.
yesturday I pulled the secondary bowl off and saw it had the spring. I guess the plastic sight plugs earned their keep although I'll never use em again. If not for one breaking i wouldn't have seen this. |
Good job.
Here are several views showing the correct orientation of the return spring to the float and bracket:
Cobalt, great thanks for taking apart those carbs. According to Bill Clinton they are still virgins.
Ive attached 4 images of MY floats which are NON METAL. I thought I mentioned this and I KNOW I mentioned this to Holley. From the pics you can see that the bracket is the same but the rest is different. There is no way to get a spring on these floats. These plastic (or whatever they call it) floats have thick plastic that covers the entire mounting rod. I think the float spring is for the metal floats only because of their weight? I took pics to show the parts as well as they way it mounts inside the fuel bowl and put the hotrodders name on there for safe keeping |
I've never seen that style of center pivot float before, all I have seen are the black nitrophyl and the soldered brass hollow floats. Only ones I've ever seen made like yours were side pivot, and I only ran into them once. Do you have any idea of the age of your carb, I'm just curious?? |
On the possible chance that I was intoxicated back then I've never seen the original floats and I usually save everything. Theres no evidence that I installed those things. |
WOW, just found a website that Ive read many times and it has BOTH my floats and the nitrophyl. The nitrophyl does not show the spring either:
http://www.hangar18fabrication.com/blowthru.html heres the pics: http://www.hangar18fabrication.com/i...move_float.JPG http://www.hangar18fabrication.com/i...led_float2.JPG |
| Setting Holley float level = gas everywhere! | Mauboo | Engine | 16 | 05-06-2010 02:37 AM |
| Holley carb - Float bowl adjustment | gilby246 | Engine | 8 | 01-16-2007 05:39 PM |
| Holley Carb Brass Float Adjustment | leejoy | Engine | 2 | 04-14-2006 09:02 PM |
| Holley 4160 on a 289 is bogging | 65fbmustang | Engine | 5 | 11-01-2004 05:59 PM |
| What holley 750cfm carb to go with ??? | FiefSS | Hotrodding Basics | 17 | 09-29-2003 03:58 PM |
