This is probally a dumb, easy question so here you
go. I've got a 4160 Holley that's been working fine up till tonight when it started flooding gas out the back vent tube any time the pedal is depressed.I've not had any problems till tonight,so this is what's bugging me.If needed it's a 454 with a 400 manual valve body. Thanks to any and all who will help. |
i had the same problem on the side of the road with my camaro it was dumping all the fuel out of the carb
i took an adjustable wrench and a screwdriver and adjusted the float adjuster on top of the bowl on the front and back After playin with the adjustment i think i adjusted it out but im not sure just play around with it and see what u get it should stop leakin, it did with me |
hi there. i think you might have picked up some rubbish in your rear needle and seat.do ya have a good fuel filter ? maybe try remmoving needle and seat blow it clean and re install and set fuel bowl level.or you might have a leaking float.good luck dood !
