Holley fuel pump, return line or not to return line??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2010, 11:20 AM
JD's camaro's Avatar
J-Man
Last journal entry: Camaro project
I need to address my fuel delivery system. Looking for insight from the best forum around.
The current fuel delivery system is as follows
1977 camaro stock tank,
Holley fuel filter mounted below tank
Holley fuel pump mount below tank
aluminum fuel line following frame to engine bay
Holley fuel regulator, one side feeds carb 750 Holley, other side feeds liquid filled fuel pressure gauge.
I bought the car 3 yrs ago, been running the fuel pump this way ever since.
Lately my fuel pump started to leak between the elctrical pump and the vain rotor housing. I'm thinking to much resistance on it because of no return line.
And the damn little holley gets hot to touch. Needless to say I am not driving it at all like this... I think the pump is shot. Leaks, get hot, sounds dangerous.
Looked at JEGS for fuel delivery diagrams and came up with this http://www.jegs.com/InstallationInst...0/650-4309.pdf.
I'm not sure if the stock tank has a return or not. getting ready to pull it.
So my question is do I need to run a return line? And should I ditch the stock tank and put in a 16 gal full cell in the trunk?
Any input would be cool.[IMG][/IMG]
Old 07-16-2010, 05:17 PM
Lately my fuel pump started to leak between the electrical pump and the vain rotor housing. I'm thinking to much resistance on it because of no return line.
I like a regulated return on an electric pump. Their output, unless digitally controlled, is continuous at full rated maximum since they do not track to engine speed like a mechanical pump. This results in a lot of thrashing of the fuel in the pump rotor chamber at low engine speeds since the engine's fuel requirement isn't much compared to the pump's output. This gets to be a bigger problem with high capacity pumps.
A regulated return certainly keeps the pump from dead-heading when the pump is running but not the engine, or from nearly dead-heading when the engine is operating from idle to highway cruise. The flow thru the pump will help draw off motor heat and prevent thrashing heat of the pump rotor trying to pump more fuel than is being used.
The pump really doesn't need to be mounted lower than the tank, the rotor chamber close to the depth of the bottom is sufficient to keep a self priming head on the pump without having it constantly faced with the pressure from the full depth of the tank. Another useful trick used mostly with fuel injection systems, but is a good idea also with a carb, especially for a race engine is to place a small auxiliary tank ahead of the pump that the main tank fills by gravity. This prevents the pump from momentarily running dry as maneuvering causes fuel to slosh away from the main tank's pick up.
Bogie
Return Line on Fuel Pump 70bird Engine 1 12-01-2008 05:07 PM
Electric Fuel pump needs a return line ? XRedRavenX Engine 4 08-20-2008 12:29 AM
should i use a holley blue top or a manual fuel pump? 406 ss monte Engine 18 12-10-2007 07:39 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
