Holley giving me fits - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2005, 07:02 AM
anthonyc's Avatar
Good Morning, I have a Holley 650 dbl pump.(04777) with a proform main body
that I cant seem to get a stumble out of. I have tried a multitude of different pump nozzels and pump cams I even installed 50cc pumps . the jetting is 71 pri. 75 sec. its has a 7.5 power valve . The car is a 77 Monte with a 30 over 350 bowl blended 194/150 heads with around 9to 1 compression. Its got a comp cam with around 470 lift (I dont remember put it in a long time ago) but around that. 2,000 stall converter . The car ran very good until I put that main body on I am thinking just put the holley main body back on but I have that on there now and want to try to get it to work . I checked for vacuum leaks and there are none. The timing is set about 10 Deg. What do you guys think. Thanks (oh yeah its got a 1 inch four hole spacer too)
Old 04-05-2005, 09:06 AM
King of my Man-cave.
What is your total timing? Try to get around 35 degrees total with the initial at around 14. Also, try it without the spacer. I had a friend who is a very good carb tuner chase his tail for quite a while with a Proform center on a Holley 750. He ended up putting the Holley main body back on, it just worked better.
tom
Old 04-05-2005, 10:49 AM
Technical Support Barry Grant
If the center section is the only thing you changed before the problem started I'd swap them back to make sure you're not chasing something else that may have happened.
Old 04-06-2005, 04:06 PM
anthonyc's Avatar
Hey guys, thanks. I think I am just gonna put the holley body back on.
The car runs pretty good but just not really good . Thanks for the replys.
That lousy Holley carb cool rockin daddy Engine 30 02-29-2008 02:01 PM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 09:55 PM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 02:53 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
Holley 650 Spread Bore Kaylah Engine 4 03-03-2003 05:50 AM
