You need a few things. First you need more initial timing.
Second you need to adjust the vacuum secondarys on your carb. They are set too tight which is delaying when they come in. First get your timing correct, then take a test drive. If the timing is correct and it still delays then you need to go to a weaker spring on the secondary.
